Joined: 11/24/2020(UTC) Posts: 7  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hi, Is there a way to get value (not to set) using the API ? I would like to get the streams values (URL&Key). And http://127.0.0.1:8088/api/ does not gives back the stream values. Adding those informations in the default XML can be a solution :) Many thanks,
Originally Posted by: adebeau  Hi, Is there a way to get value (not to set) using the API ? I would like to get the streams values (URL&Key). And http://127.0.0.1:8088/api/ does not gives back the stream values. Adding those informations in the default XML can be a solution :) Many thanks, Try the vMix user.config ;-)
Hi Interesting, how do you get the user.config with API ? Thanks
Originally Posted by: adebeau  Hi Interesting, how do you get the user.config with API ? Thanks one pulls the data from that xml file using a script similar to this exporting scripts script https://forums.vmix.com/...eature-Request#post95653Curious about the use though
