adebeau
#1 Posted : Monday, September 13, 2021 6:41:55 AM(UTC)
adebeau
Is there a way to get value (not to set) using the API ?
I would like to get the streams values (URL&Key).
And http://127.0.0.1:8088/api/
does not gives back the stream values.
Adding those informations in the default XML can be a solution :)
Many thanks,
#2 Posted : Monday, September 13, 2021 2:38:11 PM(UTC)
Many thanks,
Try the vMix user.config ;-)
adebeau
#3 Posted : Monday, September 13, 2021 7:50:27 PM(UTC)
adebeau
Hi
Interesting, how do you get the user.config with API ?
#4 Posted : Monday, September 13, 2021 7:58:09 PM(UTC)
Hi
one pulls the data from that xml file using a script
similar to this exporting scripts script
https://forums.vmix.com/...eature-Request#post95653
Curious about the use though
