Feature Requests
Naming Inputs in Multiview
Rank: Guest
Groups: Guests
I wish the input windows on multiview could be named or numbered, sort of like an overlay, that could be turned on or off, as the user wishes...this would be a great asset...it would help in a case where the director could just call the take he or she wants, the same way it is on the main window... This would be a great advantage where the user prefer not to use the colour bars on the top, and use Black as I do .....We name our inputs as 'CAM 1, CAM 2' etc, and we name our clip windows, except when we use a 'List' where each clip in our list has its own Name....It is like duplicating the naming of the main screen....so, a director can just call the the takes from the 'multiview' screen, without having to look to the main screen for the name of the inputs
If you click the cog wheel on the input (bottom right corner) you can under "General" change the name of the input (ie the multi view input).
Note, perhaps a bug, but you need to close the input settings window after you have changed the name BEFORE you click Multiview to set that multiview options. And of course, the name can be changed after you have set the multiview options.
Rank: Guest
Groups: Guests
richardgatarski wrote:If you click the cog wheel on the input (bottom right corner) you can under "General" change the name of the input (ie the multi view input).
Note, perhaps a bug, but you need to close the input settings window after you have changed the name BEFORE you click Multiview to set that multiview options. And of course, the name can be changed after you have set the multiview options. That does NOT work...I tried it, that is why I made this post...If you have it working, you are a lucky man...
proof is in the pudding ;) richardgatarski attached the following image(s):  a-lucky-man.png (176kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
i assume he means in the full screen multiviewer
 1 user thanked Henny for this useful post.
Ahhh, thank you Henny!
And please excuse me Bardos59 for not reading your feature request properly.
+1 Sounds like a useful feature.
Rank: Guest
Groups: Guests
richardgatarski wrote:Ahhh, thank you Henny!
+1 Sounds like a useful feature. Ah, NOW you see what I was saying.....I would prefer the multiview to have the same name as the main window...As it is now, I can only see the inputs, but I do not know which is Cam 1, Cam 2, player, or replay....That is the issue I have with the multiview....... By The Way, 'Multiview' is only in full screen...what is on the inputs is 'Overlays'
Rank: Guest
Groups: Guests
This is what I am thinking of.....having the same name on the multiview as on the main window.....the same way it is done for the Audio Mixer.....
Thanks: 32 times Was thanked: 2 time(s) in 2 post(s)
This feature is available on vMix v13, you can download it from download's page
 1 user thanked pasingshot for this useful post.
What can we say, except you did it again Martin! Much appreciated :)
Feature Requests
