binario1974
#1 Posted : Monday, September 6, 2021 3:23:36 AM(UTC)
binario1974
Italy
Good Morning, for make a world guinness record, we need to create a counter-up with the hour counting over the day 24h limits.
The counter must stay on top inside every PGM video output, with the option to pause/play the counter with a simple button.
We have already download vMixUTC but with all options active, is not possible force the counter to use the infinite hour count-up.
May be that some of you, can help me to fix this limit?.
Kind regards.
Luigi P
#2 Posted : Monday, September 6, 2021 3:55:33 AM(UTC)
Was thanked: 1013 time(s) in 832 post(s)
Use an overlay and do not change it
You mean actually stop the counting and resume later from where it left off ?
Might have to write your own little script to convert the timespan
binario1974
#3 Posted : Monday, September 6, 2021 4:31:58 AM(UTC)
binario1974
Italy
Hi Thanks!.
I have read the txt file Functions.xml, but I am not sure what need to modify.
For the buttons start/stop we have understand the options, the difficult is
only find the option.
Sure that this enhancement, when ready, can be useful for other guys.
I suggest when possible to add this option, directly inside Timer Widget.
Kind Regards.
Luigi P.
binario1974
#4 Posted : Monday, September 6, 2021 6:49:45 AM(UTC)
binario1974
Italy
HI Guys.
Problem Solved!!!
Downloaded and installed a little app called SNAZ.
With this app, I have all kind of timer, counterUp and Down, with the Hours/days options.
After start and configured, we link a generated txt file with vMix, by reading this file as external TXT source, and all work GOOD!
Kind Regards to All.
Luigi Pavia - Italy
thanks 1 user thanked binario1974 for this useful post.
doggy on 9/6/2021(UTC)
