G.W.R. stopwatch Hours based, without 24H day change
Joined: 9/6/2021(UTC) Posts: 3  Was thanked: 1 time(s) in 1 post(s)
Good Morning, for make a world guinness record, we need to create a counter-up with the hour counting over the day 24h limits. The counter must stay on top inside every PGM video output, with the option to pause/play the counter with a simple button.
We have already download vMixUTC but with all options active, is not possible force the counter to use the infinite hour count-up.
May be that some of you, can help me to fix this limit?.
Kind regards. Luigi P
Originally Posted by: binario1974  The counter must stay on top inside every PGM video output,
Use an overlay and do not change it Quote:with the option to pause/play the counter with a simple button.
You mean actually stop the counting and resume later from where it left off ? Might have to write your own little script to convert the timespan
Hi Thanks!. I have read the txt file Functions.xml, but I am not sure what need to modify. For the buttons start/stop we have understand the options, the difficult is only find the option.
Sure that this enhancement, when ready, can be useful for other guys. I suggest when possible to add this option, directly inside Timer Widget.
Kind Regards. Luigi P.
HI Guys.
Problem Solved!!! Downloaded and installed a little app called SNAZ.
With this app, I have all kind of timer, counterUp and Down, with the Hours/days options.
After start and configured, we link a generated txt file with vMix, by reading this file as external TXT source, and all work GOOD!
Kind Regards to All.
Luigi Pavia - Italy
 1 user thanked binario1974 for this useful post.
