NDI
Has anyone got 1080p50 working with no dropped frames?
Joined: 10/14/2016(UTC) Posts: 64 Location: Sheffield
Having a real issue getting 1080p50 to work smoothly over NDI and wondered if anyone had any insights/suggestions to get us sorted.
Current setup for testing is BMD URSA Broadcast at 1080p50 Camera goes SDI into a Kiloview E1 encoder set to NDI HX, NDI HX2, unicast or multicast makes no difference Encoder goes into a Netgear M4250 24 port switch with the NDI profile enabled on the ports Laptop is a gaming laptop with an RTX 2060, i7, 32GB RAM, SSD etc. Laptop is into the Netgear switch also with NDI profile enabled Laptop has Gigabit port vMix preset has nothing in it except the camera input and is set to high performance mode
Issues/tests so far: If I open the statistics view, it sheds frames at an alarming rate and therefore we get stuttering feed If I step it down to 30p or 50i, it's fine If I tick the "increase buffer" box before adding the input it runs fairly ok at 50p but still drops a few frames
Based on the fact that if I lower the rate of data (via frame reductions) or increase the buffer it gets better it seems like I'm having some kind of buffering issue. What I don't know is what the buffer is (RAM etc.) or how big or small it can be. And also if there is a setting/spec we can change that will increase the throughput that means that we do not need to run the increased buffer at all.
Any help would be greatly appreciated!
I'm assuming that's a negative.
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
What does vmix report GPU/CPU stats as (lower left)? What does performance monitor report NIC throughput as?
There's definitely a major issue somewhere in your chain. I'm sure someone has written up an NDI troubleshooting/performance checklist somewhere.
NDI
