Damn2Good4U
#1 Posted : Wednesday, May 14, 2014 6:27:48 AM(UTC)
Damn2Good4U
I think its time Martin should be looking at integrating 3D virtual sets into vMix...
I absolute believed this can be achieved if the likes of Tricaster can so is vMix.. This will open many doors and opportunities with loads of other broadcasters around the globe.
We just want to see vMix to be the best software video switcher...
#2 Posted : Wednesday, May 14, 2014 7:57:52 AM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
What specific virtual set features are you looking for?
To clarify, the Virtual Sets on the Tricaster are made up of pre-rendered static 3D images just like vMix.
They have a couple of additional effects that make them look a bit more three dimensional, but the underlying method is actually the same.
Damn2Good4U on 5/14/2014(UTC)
Damn2Good4U
#3 Posted : Wednesday, May 14, 2014 8:45:35 AM(UTC)
Damn2Good4U
Achieving the 3D effects is what I am actually thinking will be very good for vMix...
#4 Posted : Wednesday, May 14, 2014 9:15:25 AM(UTC)
Can you be more specific?
Damn2Good4U
#5 Posted : Wednesday, May 14, 2014 10:04:13 AM(UTC)
Damn2Good4U
The 3 dimensional movement of a camera around Talents or within a studio
Something like this here:
Shift Left Video Sample
Shift Right Video Sample
#6 Posted : Wednesday, May 14, 2014 11:20:20 AM(UTC)
Ok, I see what you mean, but you won't find that sort of effect on a Tricaster either as it just uses pre-rendered stills like vMix.
There are some very high end 3D virtual set technologies out there (such as from Vizrt) but they all
use very specialised (and very expensive) hardware in order to render and track everything in real time.
nandhitv
#7 Posted : Tuesday, May 20, 2014 5:03:36 PM(UTC)
nandhitv
+1 for this feature
richardgatarski
#8 Posted : Wednesday, May 21, 2014 3:14:34 AM(UTC)
richardgatarski
Rank:: Advanced Member
Damn2Good4U don't you need camera movements to be in sync with the background image movement to obtain what your demo video shows?
I guess you already can do a somewhat static 3D virtual effect in vMix by having one virtual set for each camera position.
Damn2Good4U
#9 Posted : Wednesday, May 21, 2014 8:49:09 AM(UTC)
Damn2Good4U
I guess that suggestion makes a whole lot of sense... i will try it out...
r@wisla
#10 Posted : Thursday, May 22, 2014 6:13:00 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
admin wrote:
What specific virtual set features are you looking for? (...)
- real time reflections on the table
- zoom in/out
would be great ;)
siliconsorcery
#11 Posted : Sunday, May 25, 2014 3:52:26 PM(UTC)
siliconsorcery
Serious Magic Ultra 2 used pre-rendered 3D video animations that included chroma key tracking information for each frame of the animation. This allowed chroma keyed talent and other objects to animate correctly in the 3D scene. Ultra was a post production tool there for could but be used for live productions. Serious Magic the company was purchased by Adobe many years ago and Ultra was discontinued.
Examples ...
It is time for the magic to return. This time in a live switching environment ... vMix
siliconsorcery
#12 Posted : Sunday, May 25, 2014 4:39:38 PM(UTC)
siliconsorcery
BluffTitler (http://www.outerspace-software.com/) is a real-time 3D video effects application for Windows that produces some amazing results. I have used BluffTitler in a number of live and post productions.
Recent template packs allow prerecorded chroma keyed talent to be rendered real-time in virtual studios. Because the chroma keyed footage must be captured before hand the virtual studios are therefore only available for use in a post production environment.
Examples:
Virtual Sets
http://www.outerspace-so...are.com/bixpack/pack?p=1
Broadcast Style Graphics
http://www.outerspace-so...re.com/bixpack/pack?p=14
Imagine the power of combining vMix with BluffTitler. A marriage to disrupt the live video world.
Damn2Good4U
#13 Posted : Sunday, May 25, 2014 10:46:56 PM(UTC)
Damn2Good4U
I am in for this... Martin please research into how you can marry the two and let the rest follow....
The system requirement is not much see it here - "A graphics card with at least 256 MB video memory (1 GB recommended for full HD rendering)"
This will be a marriage made in heaven
Rinsky
#14 Posted : Tuesday, May 27, 2014 8:27:50 PM(UTC)
Rinsky
That would be awesome!
I already used Blufftitler before, it's really easy to created some neat animations, great program.
Troviss
#15 Posted : Wednesday, November 5, 2014 2:19:36 AM(UTC)
Troviss
I looking for sets with reflection in the desk or floor, but can´t find anyone. Can someone tell where to find such compatible sets for vMix? I asked a company but they said that it was not compatible for vMix, but they should make it compatible if I payed a lot, but it was to expensive for me.
I use some jpg from a studioset and when I want to change camera position I use three zoom effekts from same jpg. It means that I must create three jpg with same studio motive. It works nice, but there are no reflections from my hands and arms in the desk. Where can I find such studiosets as can be used in vMix?
Is it difficult to create that for you Martin, so reflections can be used as an effect in vMix?
ask
#16 Posted : Wednesday, November 5, 2014 5:54:14 PM(UTC)
ask
This has been available since vMix13. Read the release notes. http://www.vmixhd.com/download.aspx
There is also a free template in vMix for you to try and modify.
Please do a search on the forum for further info.
tnorrell on 12/8/2014(UTC)
Guest (8)
