fabfab10
#1 Posted: : Thursday, August 26, 2021 5:33:29 PM(UTC)
fabfab10
Italy
Hello we use Vmix 4K in a remote studio, mainly with SDI output with a blackmagic card and wired internet connection on a desktop computer. I have noticed that i'm not able to start vmix if ethernet cable is unplugged. The splash screen hangs forever and it never starts.
I have a copy running on my notebook which behave differently.
Does anybody have an idea what could be wrong?
I have also tried to disable check for updates on startup.
nutellazpw-
#2 Posted : Thursday, August 26, 2021 5:38:44 PM(UTC)
nutellazpw-
Serbia
It's because of license check.
Sofware must to check if the license is valid or not, and that's not possible to do without inet connection.
fabfab10
#3 Posted : Thursday, August 26, 2021 5:57:19 PM(UTC)
fabfab10
Italy
Thanks for your reply, but i have to disagree with you: i can run it on my laptop with no internet connection, so should be something different
richardgatarski
#4 Posted : Thursday, August 26, 2021 6:12:23 PM(UTC)
richardgatarski
I think you have connect at least once when installing, and also if major changes in hardware cause vMix to validate again.
Ask vMix support.
