Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
Hello, Ok Martin said about Latency and other stuff? when it comes to multi gpu. I just want to put in a secondary GPU Just for extra Monitors, no performance benefit. Would that be ok? Thanks.
Joined: 10/13/2012(UTC) Posts: 1,162 Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
This is not recommended. Please refer to Martins explanations (multiple) in the forum and on the FTLS.
(vMix) Fun Time Live Show
yeh, but my question a little different? i saw that latest ftls, and it was mainly more about using 2 cards, for performance. i just like more monitors in my windows enviroment. i found a single card with 6 outputs. so ill get that.
Joined: 7/1/2015(UTC) Posts: 1,151 Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
vMix only uses one GPU. Adding a second causes problems.
You're better off getting a card with more outputs, or using NDI to send extra outputs elsewhere via network.
yes, thank you, got a card with 6 outputs, backordered. thanks!
