hellokitty
#1 Posted : Wednesday, August 18, 2021 2:19:31 PM(UTC)
hellokitty
Hello, Ok Martin said about Latency and other stuff? when it comes to multi gpu. I just want to put in a secondary GPU Just for extra Monitors, no performance benefit. Would that be ok? Thanks.
ask
#2 Posted : Wednesday, August 18, 2021 2:32:55 PM(UTC)
ask
This is not recommended. Please refer to Martins explanations (multiple) in the forum and on the FTLS.
hellokitty
#3 Posted : Wednesday, August 18, 2021 3:03:37 PM(UTC)
hellokitty
whats FTLS?
SportsNetUSA.net
#4 Posted : Wednesday, August 18, 2021 3:48:38 PM(UTC)
SportsNetUSA.net
(vMix) Fun Time Live Show
hellokitty
#5 Posted : Wednesday, August 18, 2021 4:00:11 PM(UTC)
hellokitty
yeh, but my question a little different? i saw that latest ftls, and it was mainly more about using 2 cards, for performance. i just like more monitors in my windows enviroment. i found a single card with 6 outputs. so ill get that.
mjgraves
#6 Posted : Tuesday, August 24, 2021 4:45:01 AM(UTC)
mjgraves
vMix only uses one GPU. Adding a second causes problems.
You're better off getting a card with more outputs, or using NDI to send extra outputs elsewhere via network.
hellokitty
#7 Posted : Tuesday, August 24, 2021 8:57:41 AM(UTC)
hellokitty
yes, thank you, got a card with 6 outputs, backordered. thanks!
Similar Topics
vmix multi gpu SLI (Hardware Compatibility)
by formatta2003 4/14/2023 4:44:59 PM(UTC)
