cmdcheshire
#1 Posted : Saturday, July 17, 2021 7:34:43 AM(UTC)
cmdcheshire
I'm trying to test the new NDI 5 I/O VST plugins using vMix and I can't seem to get vMix to recognize them. They were installed with the NDI 5 tools pack and it seems like plugins I've used in the past, they're nested in folders. So rather than
"C:\Program Files\Common Files\VST3\Plugins.VST.NDI.Output.vst3"
the plugin files are in
"C:\Program Files\Common Files\VST3\Plugins.VST.NDI.Output\Contents\x86_64-win\Plugins.VST.NDI.Output.vst3"
Moving them to the root directory breaks the plugins. Is there a way to set vMix to recognize additional plugin paths? I couldn't find anything on this.
Thanks!
Chris
Ryzen6667
#2 Posted: : Sunday, July 25, 2021 10:20:39 PM(UTC)
Ryzen6667
Netherlands
Yea same thing here, no matter what i try vmix will not find the vst3.
Bit of a bummer since almost every daw has no trouble finding it.
If anyone found a workaround please let us know
tbarden
#3 Posted : Monday, August 23, 2021 10:43:39 PM(UTC)
tbarden
+1
azanisarri
#4 Posted : Friday, March 18, 2022 7:50:31 PM(UTC)
azanisarri
Malaysia
+1
