VST3 Plugins nested in folders
Joined: 7/17/2021(UTC) Posts: 1  Location: Los Angeles
I'm trying to test the new NDI 5 I/O VST plugins using vMix and I can't seem to get vMix to recognize them. They were installed with the NDI 5 tools pack and it seems like plugins I've used in the past, they're nested in folders. So rather than Quote:"C:\Program Files\Common Files\VST3\Plugins.VST.NDI.Output.vst3" the plugin files are in Quote:"C:\Program Files\Common Files\VST3\Plugins.VST.NDI.Output\Contents\x86_64-win\Plugins.VST.NDI.Output.vst3" Moving them to the root directory breaks the plugins. Is there a way to set vMix to recognize additional plugin paths? I couldn't find anything on this. Thanks! Chris
Joined: 4/27/2021(UTC) Posts: 14  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Yea same thing here, no matter what i try vmix will not find the vst3.
Bit of a bummer since almost every daw has no trouble finding it.
If anyone found a workaround please let us know
Joined: 10/2/2020(UTC) Posts: 8  Location: So. Burlington, VT
Joined: 10/17/2018(UTC) Posts: 22  Location: Rawang Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
