baz06
#1 Posted : Monday, May 19, 2014 11:25:56 PM(UTC)
baz06
Hi
I'm using vMix to capture 2 relatively high end IP cameras to create one stream. While looking at the comers' viewer (an http page) or VLC, the video is fluid.
However, When I open the stream in the vMix, the picture becomes strobe, in the Input as well as in the Preview or Program. It happens on 1920X1080, 25fps and 1280X720, 25fps.
I tried 50p, 25i, 50p and even 60p, 30i. The picture still strobe.
Boaz
Description:
Camera: Dlink DSC 3716
Stream: h.264, Quality – Exhalent
FPS: 25 (max)
Network: LAN 1G
PC:
Intel i7-3770, 3.40 GHz
RAM 16G
Win 7 64-bit
GeForce GT 630,
Version: 314.07
Video memory: 2 G DDR3
Shared system memory: 2G
Bus: PCI Express x16 Gen2
BIOS: 70.08.AE.00.00
Chipset: PCI\VEN_8086&DEV_1E49&SUBSYS_50011458&REV_04
Default definitions
#2 Posted : Tuesday, May 20, 2014 3:51:29 AM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
A couple of things you can check:
1. Make sure the latest version of vMix is installed (12.0.0.129)
2. What settings have you selected when adding the stream to vMix? Try increasing the buffer size.
3. The frame rate in vMix Settings should be 50i/25p to match the 25p in the camera settingsa.
4. Click the statistics button and provide a screenshot:
http://www.vmix.com.au/help12/Statistics.html
baz06
#3 Posted : Tuesday, May 20, 2014 12:58:42 PM(UTC)
baz06
Hi Martin
The version is 12.0.0.129
The buffer for the MP4 stream is 300 ms. I've tried to increased it to 600ms, but is was the same.
Frame rate is 50i/25p
How do I add here the stat. screenshot?
Boaz
SKYGIF
#4 Posted : Tuesday, May 20, 2014 1:56:45 PM(UTC)
SKYGIF
For a screenshot all you do is click print screen at the top right corner of the keyboard. Then paste it in a new photoshop document...then crop it to the right size... or you can paste it in PAINT if you don't have photoshop. Save the file as jpg and post. If you're on a mac I'm not sure.
baz06
#5 Posted : Tuesday, May 20, 2014 2:16:30 PM(UTC)
baz06
Hi
The Insert Image allows me insert only Image Tag:
[img][/img]
Is there is an Email I can send it to?
Boaz
