sunkast
#1 Posted : Wednesday, August 18, 2021 3:31:25 AM(UTC)
sunkast
Is there anyway to set the file name for a recording via a script? This could happen either before or after the start of a recording. I try to add the episode number for all of my shows in the file name of the recording. But this is a bit cumbersome to set each time having to go into the recording settings, especially when I have a shortcut setup to make starting the recording when I am ready easier. I end up forgetting to change the file name every time I start recording. I would love it if there was some way to run a script that would prompt me for the episode number either at the beginning or end of recording my show.
#2 Posted : Wednesday, August 18, 2021 4:03:48 AM(UTC)
Sure you can , after the recording.
the vMix knowledge base has an example to load a recording when it finishes recording, one can adjust it to renaming that file
Part of a production is not to forget things ;-)
sunkast
#3 Posted : Wednesday, August 18, 2021 5:02:01 AM(UTC)
sunkast
I don't need to add it to my production. I just simply want a prompt to ask me what to name the file via a shortcut that automatically runs before or after recording.
#4 Posted : Wednesday, August 18, 2021 5:22:03 AM(UTC)
I did say one can adjust (modify) the script as in rename the filev( or ask for ) instead of loading the file into the production !!!!!!!!!!!!!!!!!!!!!!
It is just a example on how to find the last recording, what you then do with it is up to you to program in the script !
You have to make your own script to do what you want it to do. ( practically anything one can do in vb.net code/scripting )
sunkast
#5 Posted : Wednesday, August 18, 2021 5:35:28 AM(UTC)
sunkast
Found this other post that has a vbscript that does exactly what I am looking for.
https://forums.vmix.com/...ecord-Filename#post91438
#6 Posted : Wednesday, August 18, 2021 10:51:04 AM(UTC)
Notice its 99% the script from the knowledge base ;-)
