How to quickly re-assign inputs to layers in multiview
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Originally Posted by: iperione  I'm trying to do the same using the SetMultiViewOverlay - Set Input as Multiview Overlay Layer function but it is not possible to use dynamicValueX for the "Layer" param, but I can use DynamicInputY for the first Input and "Input to use on Layer" params...
do you have any idea on how could be possible to use a var for the Layer in order to reach that goal using bitfocus companion? I think the answer is to add a Feature Request to allow dynamic values to be used for layer/index values in shortcuts, so I'de added one here: https://forums.vmix.com/...-parameters-in-ShortcutsHaving said that, I think there is probably a workaround using scripts. I've never tried triggering a script from a StreamDeck, but it's easy to read the dynamic values from the API using a script, so one could use StreamDeck buttons to set different dynamic values for the target multiview, the target layer and the desired input, and then trigger a script to read those values and build the SetMultiViewOverlay shortcut.
Joined: 9/22/2020(UTC) Posts: 45  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
For the companion module using the Routable "Layers" / "multiview overlays" the variable are stored in companion itself, not in vMix Dynamics. Also some commands are not accepting Input name/guid at the moment (why im not using it at the moment). It is a bug that I have reported. It should be fixed in a future version.
For the moment im using the Dinamics in vMix in the sequence : Target Input -> Source Selection -> Layer change. this setup is fonctional for 10 sources & 20 different layout, with a max of 10 source at once in some layout (obviously)
Originally Posted by: Howlswolf  For the moment im using the Dinamics in vMix in the sequence : Target Input -> Source Selection -> Layer change. this setup is fonctional for 10 sources & 20 different layout, with a max of 10 source at once in some layout (obviously)
Can you post an example of this? I found a similar solution, with the same sequence.... but I used dynamic source... First I select a multilayered input (setting DynamicInput1 to its value) Than I select the input I want to use as feed (using DynamicInput2) at the end I have to select the layer in this way... IE for layer 2 xxxx check next post xxxx
Originally Posted by: iperione  setmultiviewoverlay - set input as multiview overlay layer Input=Dynamic1&Value=2&Value=Dynamic2
Twice Value ? Use SetLayer function now Input= Dynamic1 (SetDynamicInput1 with the input details) Value= Dynamic1 (SetDynamicValue1 with the "Index,input" details)
Originally Posted by: doggy  Originally Posted by: iperione  setmultiviewoverlay - set input as multiview overlay layer Input=Dynamic1&Value=2&Value=Dynamic2
Twice Value ? Use SetLayer function now Input= Dynamic1 (SetDynamicInput1 with the input details) Value= Dynamic1 (SetDynamicValue1 with the "Index,input" details) sorry my fault, I was involved in too many discussions and I made a mistake... This is my right sequence: first selection: (select multiview input) SetDynamicInput1 Value=1 step two: (select input to feed the layer) SetDynamicInput2 Value=3 Select Layer to be feeded with input (dynamic2) SetLayer Input=Dynamic1&Value=2,Dynamic2 In this way in the multilayerd input 1 we can assign to Layer 2 the input number 3
