2 Pages<12
matkeane
#21 Posted : Monday, August 9, 2021 6:45:18 PM(UTC)
matkeane
Was thanked: 21 time(s) in 21 post(s)
Originally Posted by: iperione Go to Quoted Post
I'm trying to do the same using the SetMultiViewOverlay - Set Input as Multiview Overlay Layer function
but it is not possible to use dynamicValueX for the "Layer" param, but I can use DynamicInputY for the first Input and "Input to use on Layer" params...
do you have any idea on how could be possible to use a var for the Layer in order to reach that goal using bitfocus companion?
I think the answer is to add a Feature Request to allow dynamic values to be used for layer/index values in shortcuts, so I'de added one here:
https://forums.vmix.com/...-parameters-in-Shortcuts
Having said that, I think there is probably a workaround using scripts. I've never tried triggering a script from a StreamDeck, but it's easy to read the dynamic values from the API using a script, so one could use StreamDeck buttons to set different dynamic values for the target multiview, the target layer and the desired input, and then trigger a script to read those values and build the SetMultiViewOverlay shortcut.
Howlswolf
#22 Posted : Friday, August 13, 2021 1:02:08 AM(UTC)
Howlswolf
Canada
For the companion module using the Routable "Layers" / "multiview overlays" the variable are stored in companion itself, not in vMix Dynamics. Also some commands are not accepting Input name/guid at the moment (why im not using it at the moment). It is a bug that I have reported. It should be fixed in a future version.
For the moment im using the Dinamics in vMix in the sequence : Target Input -> Source Selection -> Layer change.
this setup is fonctional for 10 sources & 20 different layout, with a max of 10 source at once in some layout (obviously)
iperione
#23 Posted : Sunday, August 15, 2021 2:35:23 AM(UTC)
iperione
Italy
Can you post an example of this?
I found a similar solution, with the same sequence....
but I used dynamic source...
First I select a multilayered input (setting DynamicInput1 to its value)
Than I select the input I want to use as feed (using DynamicInput2)
at the end I have to select the layer in this way...
IE for layer 2
xxxx check next post xxxx
#24 Posted : Sunday, August 15, 2021 2:51:43 AM(UTC)
setmultiviewoverlay - set input as multiview overlay layer Input=Dynamic1&Value=2&Value=Dynamic2
Twice Value ?
Use SetLayer function now
Input= Dynamic1 (SetDynamicInput1 with the input details)
Value= Dynamic1 (SetDynamicValue1 with the "Index,input" details)
iperione
#25 Posted : Sunday, August 15, 2021 5:48:48 PM(UTC)
iperione
Italy
Twice Value ?
sorry my fault, I was involved in too many discussions and I made a mistake...
This is my right sequence:
first selection: (select multiview input)
SetDynamicInput1 Value=1
step two: (select input to feed the layer)
SetDynamicInput2 Value=3
Select Layer to be feeded with input (dynamic2)
SetLayer Input=Dynamic1&Value=2,Dynamic2
In this way in the multilayerd input 1 we can assign to Layer 2 the input number 3
2 Pages<12
