cutter07
#1 Posted : Thursday, August 12, 2021 4:44:19 PM(UTC)
cutter07
Is there a way run a script when vMix starts?
richardgatarski
#2 Posted : Thursday, August 12, 2021 5:44:41 PM(UTC)
richardgatarski
No, but there is at least one feature request to activate a shortcut or similar when vMix is started. Search for it in the Feature Request Forum.
cutter07
#3 Posted : Thursday, August 12, 2021 5:57:29 PM(UTC)
cutter07
Ok, thanks.
#4 Posted : Thursday, August 12, 2021 6:53:50 PM(UTC)
cutter07
#5 Posted : Thursday, August 12, 2021 7:38:53 PM(UTC)
cutter07
I thought maybe there is another possibility in "vMix" by now.
I did something like that some time ago. I have found it again.
Check with "Autohotkey" whether "vMix" has been started, then execute a shortcut in vMix with "Send".
Autostart Batch:
Code:
echo off
start C:\Apps\10_Streaming\10_Settings\10_Automation\vMix-start.ahk
start C:\Apps\10_Streaming\10_Settings\12_Preset\Gottesdienst.vmix
Autohotkey script:
Code:
WinWait ahk_exe vMix64.exe,
SetTitleMatchMode, 2
WinWait, .vmix,
IfWinNotActive, .vmix, , WinActivate, .vmix,
	WinWaitActive, .vmix,
	Send,{F8}
#6 Posted : Thursday, August 12, 2021 9:14:28 PM(UTC)
What say if a preset is not fully loaded yet ?
cutter07
#7 Posted : Thursday, August 12, 2021 9:26:04 PM(UTC)
cutter07
Good question... I don't know.
For me it worked like that, because it was a small preset, I think.
cutter07
#8 Posted : Thursday, August 12, 2021 9:29:56 PM(UTC)
cutter07
The only thing I did after the start was to change the category to red. Presumably this also works without a completely loaded preset.
apocnz
#9 Posted : Thursday, August 12, 2021 11:32:29 PM(UTC)
apocnz
I do this by having a browser input in the preset that taps the http api (ScriptStart). Does the job.
thanks 1 user thanked apocnz for this useful post.
doggy on 8/13/2021(UTC)
cutter07
#10 Posted : Friday, August 13, 2021 12:07:24 AM(UTC)
cutter07
@ apocnz: Ingenious, that's better than my first approach:
A little lateral thinking. If one plays an audio file with -18db in a loop and thus saves the "preset", the audio file is played automatically after reopening the "preset". If you now set a "trigger" in the audio file "OnAudioMeterDB18 -> SelectCategory", the category is automatically changed after the start of the "preset". Whether this makes sense is open to question.
cutter07
#11 Posted : Friday, August 13, 2021 1:42:31 AM(UTC)
cutter07
Could you post an example HTML?
#12 Posted : Friday, August 13, 2021 2:51:22 AM(UTC)
browser input with URL http://localhost:8088/api/?Function=ScriptStart&Value=Script164 for example or any other function (see helpfiles)
For use when starting from a preset
cutter07
#13 Posted: : Friday, August 13, 2021 4:54:37 AM(UTC)
cutter07
Okay thanks. I thought I had to create a HTML page which automatically executes this link :-)
