Run a script when vMix starts
Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
Is there a way run a script when vMix starts?
No, but there is at least one feature request to activate a shortcut or similar when vMix is started. Search for it in the Feature Request Forum.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
I thought maybe there is another possibility in "vMix" by now. I did something like that some time ago. I have found it again. Check with "Autohotkey" whether "vMix" has been started, then execute a shortcut in vMix with "Send". Autostart Batch: Code:echo off
start C:\Apps\10_Streaming\10_Settings\10_Automation\vMix-start.ahk
start C:\Apps\10_Streaming\10_Settings\12_Preset\Gottesdienst.vmix
Autohotkey script: Code:WinWait ahk_exe vMix64.exe,
SetTitleMatchMode, 2
WinWait, .vmix,
IfWinNotActive, .vmix, , WinActivate, .vmix,
WinWaitActive, .vmix,
Send,{F8}
Originally Posted by: cutter07  I thought maybe there is another possibility in "vMix" by now.
What say if a preset is not fully loaded yet ?
Good question... I don't know. For me it worked like that, because it was a small preset, I think.
The only thing I did after the start was to change the category to red. Presumably this also works without a completely loaded preset.
I do this by having a browser input in the preset that taps the http api (ScriptStart). Does the job.
 1 user thanked apocnz for this useful post.
@ apocnz: Ingenious, that's better than my first approach:
A little lateral thinking. If one plays an audio file with -18db in a loop and thus saves the "preset", the audio file is played automatically after reopening the "preset". If you now set a "trigger" in the audio file "OnAudioMeterDB18 -> SelectCategory", the category is automatically changed after the start of the "preset". Whether this makes sense is open to question.
Originally Posted by: apocnz  I do this by having a browser input in the preset that taps the http api (ScriptStart). Does the job.
Could you post an example HTML?
Originally Posted by: cutter07  Originally Posted by: apocnz  I do this by having a browser input in the preset that taps the http api (ScriptStart). Does the job.
Could you post an example HTML? browser input with URL http://localhost:8088/api/?Function=ScriptStart&Value=Script164 for example or any other function (see helpfiles) For use when starting from a preset
Okay thanks. I thought I had to create a HTML page which automatically executes this link :-)
