krunomstv
#1 Posted : Friday, June 18, 2021 6:22:23 AM(UTC)
krunomstv
Croatia
Hi, I have strange problem with my system. I have 2 same model Magewell 4xSDI input capture cards.
Connected to system vMix acts like both cards are the same (eg. I have only 4 inputs, not 8 as camera connected to input1 on card 1 will also show as the input 1 on 2nd card) - so is there anything I am doing wrong?
SportsNetUSA.net
#2 Posted : Friday, June 25, 2021 1:43:19 PM(UTC)
SportsNetUSA.net
From Magewell
Support for multiple cards plugged to one system
On-board rotary switch to set card number, with 16 positions from 0 to F
System hardware device tree will display “01: Pro Capture Quad SDI” when rotary switch is set to 1, and so on
The video and audio device names displayed in your software will include the card number (set by the rotary switch)
https://www.magewell.com/tech-specs/pro-capture-quad-sdi
rosenacecil
#3 Posted : Monday, August 9, 2021 6:14:35 PM(UTC)
rosenacecil
Thank you for the clarification. That helps a lot!
