mikehende
#1 Posted : Friday, August 6, 2021 4:59:01 AM(UTC)
mikehende
Hey guys, just checking to see if vMix might be able to stream music being played in Mediamonkey please? Purpose of this is for me to apply VST effects like reverb, delays e.t.c to music being played in Mediamonkey. I am assuming first of all that vMix can host/play VST's? Thx.
andreypetr
#2 Posted : Friday, August 6, 2021 9:29:52 AM(UTC)
andreypetr
Install Virtual Audio Cable. In Windows audio settings set Mediamonkey to use Virtual Cable as output audio device.
Add Virtual Audio cable in vMIX, you can do whatever after that.
thanks 1 user thanked andreypetr for this useful post.
mikehende on 8/6/2021(UTC)
mikehende
#3 Posted : Saturday, August 7, 2021 12:30:36 AM(UTC)
mikehende
Thanks, can you first tell me which option I should use for Vmix in MM please as it's showing 4 Output options?
Mediamonkey Outputs options
mikehende
#4 Posted : Monday, August 9, 2021 12:55:14 AM(UTC)
mikehende
Ok then can anyone tell me how to Add the Virtual Audio Cable in Vmix please? I click on Add Input on bottom left of Vmox then Audio but this leads to Browse in Exploerer?
#5 Posted : Monday, August 9, 2021 1:06:24 AM(UTC)
https://www.vmix.com/kno...ty-application-into-vmix
In vMix
Open vMix and select the Add Input button at the bottom left corner
Select the Audio Input tab
From the Audio Device dropdown menu select the option for: Cable Output (VB-Audio Virtual Cable)
Press OK to add to vMix
mikehende on 8/9/2021(UTC)
mikehende
#6 Posted : Monday, August 9, 2021 2:13:51 AM(UTC)
mikehende
In vMix
Thanks, I can hear the song playing in Mediamonkey but not seeing the Mediamonkey audio shwoing in the Audio Mixer's LED when a song is playing, the LED moves only whenever the word "Trial" coming from the VAC is heard.. Also I am hearing the VST delay fx in Vmix being applied only to word 'Trial' coming from the VAC?
mavik
#7 Posted : Tuesday, August 10, 2021 1:23:29 AM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
Other options would be voicemeter or dante via.
mikehende
#8 Posted : Tuesday, August 10, 2021 8:37:42 AM(UTC)
mikehende
Wouldn't that simply be a replacement for VAC which doesn't appear to be the issue here?
mavik
#9 Posted : Wednesday, August 11, 2021 12:08:11 AM(UTC)
mavik
Yes and no. I made a video that could be useful for you.
mikehende
#10 Posted : Wednesday, August 11, 2021 10:13:55 PM(UTC)
mikehende
I appreciate your efforts and help thank you. Unfortunately that is too technical for me :). I am trying to find out why I am not seeing the Mediamonkey's playing tune showing in Vmix Mixer LED's and also why the VST plugins in Vmix is not playing over Mediamonkey's tune?
WaltG12
#11 Posted : Wednesday, September 15, 2021 4:57:58 PM(UTC)
WaltG12
Without knowing anything about MediaMonkey or your particular setup, my guess would be that it's a settings issue somewhere.
Personally, my recommendation would be using music software that's designed with this type of functionality in mind, which should help reduce problems caused by trying to get it out of non-specialized software.
My personal philosophy is that it's better to use different software that does one job very well rather than a single piece of software that does everything ok-ish.
Anything designed for radio use should be easier to configure for this. I personally use PlayIt Live, which I connected to my music folder.
I route it through VoiceMeeter, but you can route it through the Virtual Audio Cable if you'd prefer.
