How to insert dynamic pics to title
Joined: 8/3/2021(UTC) Posts: 13   Location: Weihai Thanks: 4 times
Hi,everyone! At first, vMix with date source is marvelous and convennient! But problem appeared when I am trying to creat a lower third title module in vmix,containing today's weather forecast which read data from third part xml file online.The problem I encontered is that I cannot concatenate 3 seperate text feilds together like a phrase, it cannot range in order. So I change it to range them in layout with a background of image,and now I want to change the weather sates into images which is given from the xml file as a value like state2="1",and it can be compile into image url as "http://www.xxx.com/x/d1.gif".I tried to put the url in the feild of format in data souce pannel, like "http://www.xxx.com/x/d{0}.gif", but it failed. I also tried the alternative method using weather.ttf, but it can only support 10 different state, when it gives the value of 14, it will show two weather iamges of state 1 and state 4. So plz help me!
Can somebody plz can help me?
Patience !! not everyone lives in your timezone !
in order to concatenate 3 separate text fields as one you will need to use some scripting
"http://www.xxx.com/x/d{0}.gif" should be correct assuming that is the actual file name of the image is d1.gif and the data is 1
Have you looked through this forum , dealing with images linked to a data source has been addressed multiple times here!
Have you looked through this forum , dealing with images linked to a data source has been addressed multiple times here! Thank you very much, friend! And I am fairly sorry for my anxiety! You give me a rather good hint and keywords for solution, I'll try, except using scripts, because I am not familiar with that.
It seems like failed again.  Wei Xin Tu Pian _20210805232935.png (85kb) downloaded 6 time(s).
Fixed! Because this feild is Text Type
Originally Posted by: Haifeng  Fixed! Because this feild is Text Type Was just gona say :-) Guess you will now never forget that LOL
Really impressive!  Wei Xin Tu Pian _20210806003015.png (20kb) downloaded 4 time(s).
