Haifeng
#1 Posted : Tuesday, August 3, 2021 10:03:00 AM(UTC)
Haifeng
China
Hi,everyone!
At first, vMix with date source is marvelous and convennient! But problem appeared when I am trying to creat a lower third title module in vmix,containing today's weather forecast which read data from third part xml file online.The problem I encontered is that I cannot concatenate 3 seperate text feilds together like a phrase, it cannot range in order.
So I change it to range them in layout with a background of image,and now I want to change the weather sates into images which is given from the xml file as a value like state2="1",and it can be compile into image url as "http://www.xxx.com/x/d1.gif".I tried to put the url in the feild of format in data souce pannel, like "http://www.xxx.com/x/d{0}.gif", but it failed.
I also tried the alternative method using weather.ttf, but it can only support 10 different state, when it gives the value of 14, it will show two weather iamges of state 1 and state 4.
So plz help me!
Haifeng
#2 Posted : Tuesday, August 3, 2021 9:14:57 PM(UTC)
Haifeng
China
Can somebody plz can help me?
#3 Posted : Wednesday, August 4, 2021 1:13:02 AM(UTC)
Patience !! not everyone lives in your timezone !
in order to concatenate 3 separate text fields as one you will need to use some scripting
"http://www.xxx.com/x/d{0}.gif" should be correct assuming that is the actual file name of the image is d1.gif and the data is 1
Have you looked through this forum , dealing with images linked to a data source has been addressed multiple times here!
Haifeng on 3/22/2022(UTC)
Haifeng
#4 Posted : Friday, August 6, 2021 12:26:33 AM(UTC)
Haifeng
China
Thank you very much, friend! And I am fairly sorry for my anxiety!
You give me a rather good hint and keywords for solution, I'll try, except using scripts, because I am not familiar with that.
Haifeng
#5 Posted : Friday, August 6, 2021 1:30:02 AM(UTC)
Haifeng
China
It seems like failed again.
Wei Xin Tu Pian _20210805232935.png (85kb) downloaded 6 time(s).
Haifeng
#6 Posted : Friday, August 6, 2021 1:37:00 AM(UTC)
Haifeng
China
Fixed!
Because this feild is Text Type
#7 Posted : Friday, August 6, 2021 2:26:52 AM(UTC)
Originally Posted by: Haifeng Go to Quoted Post
Fixed!
Was just gona say :-)
Guess you will now never forget that LOL
Haifeng on 8/6/2021(UTC)
Haifeng
#8 Posted : Friday, August 6, 2021 2:31:32 AM(UTC)
Haifeng
China
Really impressive!
Wei Xin Tu Pian _20210806003015.png (20kb) downloaded 4 time(s).
