ticker
#1 Posted : Thursday, July 29, 2021 11:22:13 AM(UTC)
ticker
Hi all, we have been noticing our GPU has crept up to 100% in vMix - despite closing lots of unused inputs and we don't use any web links inside. "High Input Performance Mode" is ticked, too.
Currently, our GFX card is 1660/6gb with an i9 processor.
We are looking to upgrade the graphics card to 3060/12gb.
Before we proceed I just wanted to pick the brains trust as to whether it will resolve our issue. We use a Black Magic 4 HDMI input card as well.
The issue we have is when the GPU on vMix gets to about 95%, the output starts to drop frames and stutter badly. However when we look at the computers overall GPU, it's not at 95%. Much much lower (41%) for the entire computer. So we are a bit confused.
Cheers.
ask
#2 Posted : Thursday, July 29, 2021 11:38:46 AM(UTC)
ask
Check that you have turned on "High Input Performance Mode".
https://www.vmix.com/hel...dex.htm?Performance.html
ticker
#3 Posted : Thursday, July 29, 2021 11:49:17 AM(UTC)
ticker
Hey yeh that's already ticked.
ask
#4 Posted : Thursday, July 29, 2021 11:57:52 AM(UTC)
ask
Put as many video inputs, and images, into lists as you can.
https://www.vmix.com/kno...n-in-the-vmix-status-bar
Also double check you are using the NVidia graphics card not the integrated GPU
ticker
#5 Posted : Thursday, July 29, 2021 12:29:48 PM(UTC)
ticker
Hey yeh we have a NVIDIA card.
Everything is in lists.
Discovered this which is helpful. Upgrading our graphics card so we can make use of the feature.
https://www.vmix.com/kno...th-resizable-bar-support
ask
#6 Posted : Thursday, July 29, 2021 4:35:44 PM(UTC)
ask
Note you also have to update your mobo's bios and not all boards support resizable bar.
