NSCPro
#1 Posted : Wednesday, July 28, 2021 8:25:35 AM(UTC)
NSCPro
Estonia
I use the name of the rider and after the hyphen the name of the horse. Since both names are different lengths, this solution in the video below will not work.
Leaves as shown in Figure 2. Picture 1 is normal with the name I originally set up. But picture 2 should be like picture 3.
#2 Posted : Wednesday, July 28, 2021 10:03:44 AM(UTC)
Its actually called bounding intended to scale a rectangle (background) to a auto sized textbox !
if both texts are ok to be the same font and color adding both together as one before actual display script wise could do the trick.
Refer to your previous same "problem" post https://forums.vmix.com/...n-side-by-side#post87087
or check https://forums.vmix.com/...dynamic-text-field-sizes which includes a solution
NSCPro
#3 Posted : Wednesday, July 28, 2021 9:21:08 PM(UTC)
NSCPro
Estonia
In my previous post there was no same problem because the age in parentheses was a fixed size and the layer must be fixed in size and located on the right. When I used it, it happened as shown in picture 2. However, both layers must be width scaled in the present case, because both the rider and the horse's name are constantly different sizes. The link you submitted does not show how to do this in the GT program.
#4 Posted : Wednesday, July 28, 2021 9:38:37 PM(UTC)
Indeed as it should be obvious that it is currently not possible with GT titles but it is with legacy XAML titles (or other $$$ title software). The video even has the code in the comments for it.
combining 2 hidden textboxes with script is also an option
various tools for various objectives!
NSCPro
#5 Posted : Wednesday, July 28, 2021 9:52:23 PM(UTC)
NSCPro
Estonia
Is there any way you can do this through a script if I paid you for it? because I have all the graphics done in GT and don't want to do it anywhere else.
#6 Posted : Wednesday, July 28, 2021 9:58:57 PM(UTC)
pretty straightforward
below example uses 2 titles but one can add extra hidden textboxes to one title to read the content and combine as one
Code:
Do While True
Input.Find("Title 0- The Classic Green.gtzip").Text("Headline.Text") = Input.Find("Title 0- The Classic Blue.gtzip").Text("Headline.Text") & " - " & Input.Find("Title 0- The Classic Blue.gtzip").Text("Description.Text")
Sleep(250)
Loop
NSCPro
#7 Posted : Wednesday, July 28, 2021 10:45:24 PM(UTC)
NSCPro
Estonia
Code:
Do While True
Sleep(250)
Loop
I think it’s better, if you create this solution for me. It must be working on your previous script code
