Hi there,
I have a problem whit probably some settings...
I want to show my output work on a second screen (beamer) but i im trying to figure it out whit no results :(
I want to work on screen1 , and watch my work on sreen2 (beamer)
So do's anybody knows the settings ?
sorry for bad englisch , i live in belgium
greetz Mephie
Joined: 2/18/2014(UTC) Posts: 1,844 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
See the "Fullscreen" section in vMix's help file. As documented there you need to make sure that your graphics card is set to display the second screen as extended (Before you start vMix). In addition, make sure that the resolution of your second screen matches your production resolution (vMix's Settings tab) in order to optimize your CPU perfomance. And ideally the frame rate too, which reduces the risk for " tearing". You can the toggle the second screen by clicking the "Full screen" button in vMix, and right click in order to select what you want to "beam". You may alternative use a video output card (like the Black Magic Intensity Pro). This will give you added control (eg a clean feed without overlays) and reduced CPU usage. For more info see the help file for Settings/External output. Good luck!
Thx Richard for the help..
And people yes, it was a stupid little thing i forgot... if you want to publish your work in the next screen .... : -)
DO NOT FORGET TO CLICK , on the fullscreen until it apears GREEN LIGHT :-)
Greetz Mephie ;-)
