Feature Requests
Multi camera sync with NTP
As we continue to WFH, we're looking to up our production game and have music artists across the world combine for live sessions. We'll be using SRT to capture these artists and bring them into vMix. Using the JVC HC550 as an example, we can add an NTP server into that camera. If we have multiple cameras all looking at the same NTP server, then we'd love to be able to sync these inputs coming into vMix. This will also help for eSports events too.
Adding in PTP support would be great for the future, but right now, NTP sync is the ask :)
This is how JVC have it working...
This would be a reason for us to use vMix even more. +1
It would be great in order to sync multiple remote cameras easily. Streamstar software does it with the touch of a button.
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
+1 and even enable tally lights on the camera! Please!
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
Joined: 2/5/2021(UTC) Posts: 39  Location: Fort Worth Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
+1 here too! I've got LAN cameras mixed with remote cameras that I cannot figure out how to sync up.
You have been a member since:: 7/12/2020(UTC) Posts: 2  Location: Chicago, IL Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
+1 This would be great, but is this a JVC specific standard? Does any other manufacturer offer this feature and if so, is there an industry standard with which the TC is embedded as SEI? From JVC: Quote:Connected CAM camcorders are equipped with the NTP clock which can be synchronized with NTP servers, e.g. time.google.com. When this option is selected, the TC is switched to UTC and embedded in the SEI of the H.264 stream. Each decoder, synced to the same NTP server, reads the TC, buffers streams, and outputs in sync, with the specified time offset, e.g. "UTC + 1.5 sec". Edit: It appears they are using VITC. You can use SRT Mini Server (3rd party product) and then create special NDI inputs in vMix to take advantage of the feature. It would be great if vMix supported this as native feature as PTZ Optics also has it available in their new firmware.
Originally Posted by: TommyS  +1 This would be great, but is this a JVC specific standard? Does any other manufacturer offer this feature and if so, is there an industry standard with which the TC is embedded as SEI? From JVC: Quote:Connected CAM camcorders are equipped with the NTP clock which can be synchronized with NTP servers, e.g. time.google.com. When this option is selected, the TC is switched to UTC and embedded in the SEI of the H.264 stream. Each decoder, synced to the same NTP server, reads the TC, buffers streams, and outputs in sync, with the specified time offset, e.g. "UTC + 1.5 sec". Edit: It appears they are using VITC. You can use SRT Mini Server (3rd party product) and then create special NDI inputs in vMix to take advantage of the feature. It would be great if vMix supported this as native feature as PTZ Optics also has it available in their new firmware. JVC is using NTP. 100% sure. Even their sister company streamstar is using NTP for sync. Now SRT miniserver uses ntp for sync too. Even Makito decoders are using NTP for sync.
Joined: 12/3/2013(UTC) Posts: 123   Location: Arizona Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
Joined: 9/7/2024(UTC) Posts: 64  Location: The Great PNW Was thanked: 10 time(s) in 9 post(s)
Over 4 in and still this topic gets ignored like it doesn't matter. Video sync is going to be the thing that takes vMix out of contention for more and more integrations. We need bare minimum SEI sync on ingest and egress. Then support for other industry supported formats like jam sync etc. The fact that this is swept under the rug as non essential is baffling to me...
 1 user thanked offroadmediagroup for this useful post.
I 100% agree. SEI sync on ingress and egress.
+100
Feature Requests
