NDI
NDI blocked when Speedify is connected
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
Hi, I'm experiencing problems with NDI when using Speedify (VPN and bonding). The setup has two computers, connected to same gigabit switch:
1) vMix computer with NDI outputs and Speedify 2) Secondary computer in same local network receiving NDI from vMix
When the Speedify is running but not connected, NDI works fine. However, when Speedify is connected to server, NDI sources from vMix seen on computer 2 are blank, although the NDI sources are listed.
Are there any help on how to receive NDI in this case?
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
It can be that with the VPN on, a new mDNS service is created. Try to run the NDI Tools Access manager. Than you provide static NDI sources and do not rely on the automatic discovery.
Joined: 4/23/2017(UTC) Posts: 1,471  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
With Speedify a virtual network adapter is created, located in the Speedify network. Speedify is based on VPN with a lot of it's problems. You would need multiple network adapters, or VLANs with a VLAN capable NIC to work around this. Take the NDI NIC out of the Speedify network and create a network with the other computer. Sometimes you have to change the metric and or routing as well.
Hope that info helps.
You should be able to see a “Local Area Connection” powered by the “Speedify because this could block the update from getting installed. walgreenslistens
NDI
