3rd Party Software and Development
wireless Tally with VISCA to Serial converter
Hi, i have build a little wireless Tally based on the wemos mini D1 ESP8266 controller. It is completely configurable over the integrated Web interface. The state of the tally is shown with a rgb led which is full changeable over the webinterface. But that is not all. It converts VISCA UDP to VISCA Serial to control an attached cam. i have build it because i am using cisco PHD1080p12x cams for my productions. these cams only speak VISCA over serial and Vmix only speaks VISCA over Ethernet.  vTally.PNG (74kb) downloaded 1 time(s).
Joined: 5/14/2013(UTC) Posts: 152  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
Please share the source code
you can find the source code and the files for the shield needed on github: https://github.com/wasn-eu/vTallyit is work in progress, dont use it on critical jobs. i have used them now for several jobs with a max of 12 cams without greater problems.
now the project has reached productiv state.
all is running without any problems here Tally function and PTZ function for converting VISCA over IP to Serial are working.
