calihc
#1 Posted : Saturday, July 17, 2021 3:47:24 AM(UTC)
calihc
Germany
i have build a little wireless Tally based on the wemos mini D1 ESP8266 controller.
It is completely configurable over the integrated Web interface.
The state of the tally is shown with a rgb led which is full changeable over the webinterface.
But that is not all.
It converts VISCA UDP to VISCA Serial to control an attached cam.
i have build it because i am using cisco PHD1080p12x cams for my productions.
these cams only speak VISCA over serial and Vmix only speaks VISCA over Ethernet.
Henny
#2 Posted : Saturday, July 17, 2021 6:34:46 AM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
Please share the source code
calihc
#3 Posted : Saturday, July 17, 2021 7:57:33 AM(UTC)
calihc
Germany
you can find the source code and the files for the shield needed on github:
https://github.com/wasn-eu/vTally
it is work in progress, dont use it on critical jobs.
i have used them now for several jobs with a max of 12 cams without greater problems.
calihc
#4 Posted : Thursday, July 22, 2021 8:42:13 PM(UTC)
calihc
Germany
now the project has reached productiv state.
all is running without any problems here
Tally function and PTZ function for converting VISCA over IP to Serial are working.
