elduran
#1 Posted : Sunday, March 23, 2014 10:50:17 AM(UTC)
elduran
Hi
Is there any way to use Vmix switcher to control ATEM TVS?, i'm asking because ATEM is very limited for switching, but solid to encode and manage connections, releasing the computer cpu load, i think if we mix ATEM TVS with Vmix we will be close to a Tricaster, for less money.
sbpromotion
#2 Posted : Wednesday, April 9, 2014 10:21:23 AM(UTC)
sbpromotion
It will be great but don't think it is possible.
Actually, using ATS with vMix running on a PC who is an enter in the ATS (for incrustation of scoreboard essentially).
Thinking I can "inverse" and enter the ATS in vMix (using an HDMI acquisition card) for more options (like replay for example) but if this is possible, I think I will have only one image : the output of ATS.
Chris
sbpromotion
#3 Posted : Thursday, May 15, 2014 4:30:07 PM(UTC)
sbpromotion
Chris
Well buying an ExpressCard HDMI Audio Video Capture Card - 1080 p. Using "program HDMI out" of Atem Television Studio to go my computer. Detecting by vMix with no problem (except two black bars above and below, with are not when using directly Flash Media Live Encoder). Have to upgrad my licence and will try on live with this configuration who seems to be great too (can use all the fonctions of vMix, like replays, inscrustations, etc...) and have a double back-up of streaming : with the record of vMix and with the record of an other PC (Atem to Pc via USB and soft MxLight for record).
sbpromotion
#4 Posted : Friday, May 16, 2014 3:30:02 AM(UTC)
sbpromotion
sbpromotion wrote:
Well I upgrade my licence yesterday and don't work : vMix 12.0.0.129 didn't what to recognize my startech with 1920 X 1080 resolution, also the last version 8.8. did :(
sbpromotion
#5 Posted : Friday, May 16, 2014 9:25:40 AM(UTC)
sbpromotion
Rapid answer from Martin (great job really). Here are the issues :
admin wrote:
1. If you are running vMix x64, run the normal vMix version instead. (There was no 64bit vMix back in version 8)
Perfect ! Here are the issues
With aspect ratio as source : link. There is to bars above and below the image.
With aspect ratio as normal : link
admin wrote:
2. Try selecting 720x576 as the resolution as a test and report back the error.
Here is the issue : link. If you can't see well, the source image is reduce and seems to have to image surperpose one on one.
Thanks a lot for rapid answer and issues :) will make more tests for new live stream off bocce with wonderdul perspectives.
Regards.
Chris
#6 Posted : Friday, May 16, 2014 9:39:21 AM(UTC)
@ Chris
Somehow, your vMix appears to be configured to 4:3 aspect ratio and not 16:9.
Have you adjusted your settings since upgrading?
sbpromotion
#7 Posted : Saturday, May 17, 2014 2:34:11 AM(UTC)
sbpromotion
IceStream wrote:
@ your vMix appears to be configured to 4:3 aspect ratio and not 16:9.
Hi Ice,
Your rights ! Didn't make change :) Will did it on afternoon
Have to rediscover all settings and fonctions of vMix yet.
Thanks a lot !
Chris
