adambou
#1 Posted : Wednesday, July 7, 2021 10:11:13 PM(UTC)
adambou
data source.jpg (16kb) downloaded 1 time(s).
Which of these options do i select if i want to add an image as a data source?
I dont know what im missing but I just cant get it working.
#2 Posted : Wednesday, July 7, 2021 11:01:39 PM(UTC)
NONE of them
Datasources are files that have some type of list/table structure which an image is not
A data source (list) can have references to images stored somewhere else
That is what you are missing : the understanding between a list and an image so of course one can not make it work (if one knows what you would be trying to do then ....)
BTW :
adambou on 7/7/2021(UTC)
adambou
#3 Posted : Wednesday, July 7, 2021 11:54:53 PM(UTC)
adambou
If your title includes an image field, this can also be assigned to a data source. - This is what i want to do.
The data source text data must be either a full URL or file path in order to load correctly.
For example
http://www.example.com/image.jpg
So how do i assign an image to a title using data source? does my excel spread sheet need to somehow point to a URL of an image online?
#4 Posted : Thursday, July 8, 2021 1:10:02 AM(UTC)
BTW why another post if you didn't fully understand the answers in your previous one ? https://forums.vmix.com/...20-JPGs-as-a-Data-source
You quote exactly what is written in the helpfiles being the data in your table must contain the full external or local link as per your example ( YES your excel sheet needs to point to it)
You connect the data to the title be it text or the link to the image .of course the title needs to have an image holder instead of a text holder for this to work
You can simplify this however ( as mentioned in your other post !) by having just the name of the file in your datasource and use the format to add the location et
