3 Pages<123
ClementN
#41 Posted : Wednesday, May 7, 2014 3:08:48 AM(UTC)
ClementN
Romania
On my installation a color input is transitioned to the Program but is not displayed.
I mean in the titlebar of the Program reads "Colour" but the screen is still black (the color should be red)
Is this a known problem ?
Thank you,
#42 Posted : Wednesday, May 7, 2014 4:07:34 AM(UTC)
Which option box did you select when adding the input?
Selecting "Transparent" will make the input see through, while "Colour" will set it to the colour.
dodgepong
#43 Posted : Wednesday, May 14, 2014 4:44:24 PM(UTC)
dodgepong
I made a separate thread for this (thread here, but I figured I might as well include it here, in case this is a better place for it.
There seems to be a bug with RTMP input where, if I add the input when someone is already streaming to the RTMP URL, then the source will freeze after a few seconds. If the input has been added to vMix before the stream begins, or if the streamer restarts the stream after the input exists, then it will work fine.
sbpromotion
#44 Posted : Friday, May 16, 2014 3:42:41 AM(UTC)
sbpromotion
Hi Martin,
Have a problem. I upgrade my HD licence yesterday. Last version use : 8.0.0.56.
Before upgrade, test to import with succes video from Atem Television Studio via ExpressCard. Work fine. Here is the capture. (dont find how to include it directy on post) and here is the result with the image on vMix.
After the upgrade (12.0.0.129), don't success to import the image via the same way :( . Here is the message of error.
Made a test with Flash Media Live Encoder in direct capture and it still work : the 1920 X 1080 is automaticaly detected.
Thanks.
Christophe (from France)
Matérial :
1 Atem Television Studio
Cameras running 1980 X 1080, 50i
1 ExpressCard HDMI Audio Video Caputre Card - 1080p, Startech.com
1 Sony Vaio VPCF1, Windows 7 Edition Familiale Premium, 2009
Graphic Card NVIDIA GeForce GT 425 M
Processor Intel Core i5 CPU M460 2.53 Ghz
RAM 4 Go
64 bits
Streaming via Dailymotion plateform with official account
From vMix 8.0.0.56 to vMix 12.0.0.129 HD Edition
#45 Posted : Friday, May 16, 2014 5:53:07 AM(UTC)
A couple of things to try:
1. If you are running vMix x64, run the normal vMix version instead. (There was no 64bit vMix back in version 8)
2. Try selecting 720x576 as the resolution as a test and report back the error.
vMIx
sbpromotion
#46 Posted : Friday, May 16, 2014 9:23:33 AM(UTC)
sbpromotion
Perfect ! Here are the issues
With aspect ratio as source : link. There is to bars above and below the image.
With aspect ratio as normal : link
Here is the issue : link. If you can't see well, the source image is reduce and seems to have to image surperpose one on one.
Thanks a lot for rapid answer and issues :) will make more tests for new live stream off bocce with wonderdul perspectives.
Regards.
Chris
#47 Posted : Monday, June 2, 2014 9:13:20 AM(UTC)
An update has been released to vMix 12 (12.0.0.131)
Fixes:
* MOV/MXF playback issues fixed when used with Stingers/Overlay
This update can found on the web site Download page.
madness on 6/3/2014(UTC)
Guest (6)
3 Pages<123
