VW001
#1 Posted : Thursday, June 24, 2021 3:17:15 AM(UTC)
VW001
I am having an issues when I add an short to another under the advanced tab,
I find that its not reliably triggering both shorts when I press the key that has all the shortcuts set too. Bringing up 2 layers at once.
if I press the key multiple times then it triggers the added shortcuts one at a time, when I need them to go all at once.
however the layer number both light up as if both layers are on, when only layer 1 is up and 2 is not
Am I missing something in setting up the shortcuts using the advanced tab or is this a bug in Ver 24.0.0.62?
thanks
#2 Posted : Thursday, June 24, 2021 3:28:51 AM(UTC)
Layers or overlays ?
Some functions take a bit of time so better of to put the functions in a script and add a pause to it
As you mention light up i think yyou mean to say overlays, if so do they have animations etc, as that also influences the timing
Specific function used is also important, some are on/ff and others are separate for on and off
I doubt things have changed between 2 updates in regards ot the shortcuts so highly unlikely the lastest would suddenly have a bug in that area
VW001
#3 Posted : Thursday, June 24, 2021 4:23:02 AM(UTC)
VW001
sorry I meant overlays.
