I am having an issues when I add an short to another under the advanced tab, I find that its not reliably triggering both shorts when I press the key that has all the shortcuts set too. Bringing up 2 layers at once. if I press the key multiple times then it triggers the added shortcuts one at a time, when I need them to go all at once. however the layer number both light up as if both layers are on, when only layer 1 is up and 2 is not
Am I missing something in setting up the shortcuts using the advanced tab or is this a bug in Ver 24.0.0.62?
thanks
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: VW001  however the layer number both light up as if both layers are on, when only layer 1 is up and 2 is not
Layers or overlays ? Some functions take a bit of time so better of to put the functions in a script and add a pause to it As you mention light up i think yyou mean to say overlays, if so do they have animations etc, as that also influences the timing Specific function used is also important, some are on/ff and others are separate for on and off I doubt things have changed between 2 updates in regards ot the shortcuts so highly unlikely the lastest would suddenly have a bug in that area
