Joined: 3/7/2021(UTC) Posts: 5  Location: Baltimore Thanks: 1 times
I'm currently using the APC40 to control VMix. I've noticed of late that pretty much all Midi commands are very latent. Sometimes it can be as much as 2 seconds between pushing a button or fader and Vmix responding.
The APC is connected directly to my tower with no hubs or adapters and the USB port is a 3.0 connection.
Perhaps there is something I can do to reduce this or troubleshoot its cause?
Setup: vMix 4k- 24.0.0.59x64 Windows 10.0.19041 Motherboard Asus PRIME x299-A II CPU i9-10980XE RAM 64GB DDR4
Rank:: Advanced Member
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Sounds like a power issue maybe, are you sure you're not overloading a USB port?
 1 user thanked Vince Beck for this useful post.
After further investigation, it does appear that the USB port was sharing resources with other ports and this was the issue.
