Red Emerald
#1 Posted : Friday, June 18, 2021 6:12:23 AM(UTC)
Red Emerald
I'm currently using the APC40 to control VMix. I've noticed of late that pretty much all Midi commands are very latent. Sometimes it can be as much as 2 seconds between pushing a button or fader and Vmix responding.
The APC is connected directly to my tower with no hubs or adapters and the USB port is a 3.0 connection.
Perhaps there is something I can do to reduce this or troubleshoot its cause?
Setup:
vMix 4k- 24.0.0.59x64
Windows 10.0.19041
Motherboard Asus PRIME x299-A II
CPU i9-10980XE
RAM 64GB DDR4
Vince Beck
#2 Posted : Friday, June 18, 2021 9:27:31 AM(UTC)
Vince Beck
Sounds like a power issue maybe, are you sure you're not overloading a USB port?
thanks 1 user thanked Vince Beck for this useful post.
Red Emerald on 6/18/2021(UTC)
Red Emerald
#3 Posted : Friday, June 18, 2021 11:57:25 AM(UTC)
Red Emerald
After further investigation, it does appear that the USB port was sharing resources with other ports and this was the issue.
