Feature Requests
Elgato Stream Deck Toggle Request
Hello, I searched around to see if this request had already been talked about and couldn't find one specifically so I apologize if there is one already started that I didn't find.
What I am requesting is to have an option in the vMix plugin for Elgato Stream Deck of a Toggle switch. I run a lot of video production, and rarely do I want my mic to be on, so I use a button to mute and unmute my mic with a shortcut for Audio On/OFF currently mapped for with a Hotkey. Then in Stream Deck I use a system hotkey toggle and 2 graphics to show on and off. It would be great if I could have the actually vMix shortcut be a toggle, then I could just map the graphics to the toggle.
The reason this makes a difference, is that during productions I will occasionally need to open another program to do something, if this is happening and I use my hotkey it won't work because vMix is not the in focus program. If it was a direct shortcut key it would still work the same as my other keys.
This would be super helpful for me to monitor on the stream deck if I am activating or deactivating something like a mic or an overlay.
Thanks!
Joined: 4/19/2020(UTC) Posts: 7  Location: Minneapolis Thanks: 1 times
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: Rome  The reason this makes a difference, is that during productions I will occasionally need to open another program to do something, if this is happening and I use my hotkey it won't work because vMix is not the in focus program.
Why make it so difficult? Don't use the Stream Deck hotkey to link to a shortcut in vMix but use the website option and give it the webrequest option for the same (shortcut)function . no issue with needing to have vMix GUI in focus or have to resort to companion (as if that is the solution to every SD use) . While the vMix streamdeck plugin makes it easy to create a vMix shortcut linked to the SD it also can create issues especially when Switching or moving streamdecks.
Joined: 7/17/2020(UTC) Posts: 59  Location: Makati City Thanks: 11 times Was thanked: 5 time(s) in 5 post(s)
Feature Requests
