Xavi137
#1 Posted : Saturday, June 12, 2021 7:05:00 AM(UTC)
Xavi137
Does Gt designer have the function of a variable size box depending on the length of the text?
In other words, the width of the box adjusts perfectly and automatically according to the length of the text.
#2 Posted : Saturday, June 12, 2021 7:41:55 AM(UTC)
Yes
vMix YT has a video for it (Auto Scaling Titles)
Xavi137 on 6/12/2021(UTC)
Xavi137
#3 Posted : Saturday, June 12, 2021 5:09:04 PM(UTC)
Xavi137
Originally Posted by: doggy Go to Quoted Post
Yes
I've already made it. Thank you very much.
Two more questions:
Two blocks of text that you want to go in the same line. One right after the other.
Then the function to make the text size smaller if all the text does not fit in the rectangle.
Thanks in advance
#4 Posted : Saturday, June 12, 2021 5:19:06 PM(UTC)
Assume you mean they position of second has to adjust its position according the length of the first ?
Not with GT title but can be done with Legacy XAML titles
If you hover over this button one gets the message : "Configure Automatic Text Box Resizing"
Xavi137
#5 Posted : Saturday, June 12, 2021 5:22:29 PM(UTC)
Xavi137
The second question I have already found.
It is "Shrink" but it is not to my liking. It should combine auto scaling box up to a limit and then go to reduce font size. A combination of "Width" and "Shrink".
Xavi137
#6 Posted : Saturday, June 12, 2021 5:25:54 PM(UTC)
Xavi137
Yes, This
The reason is to be able to make two different fonts in the same sentence.
#7 Posted : Saturday, June 12, 2021 5:45:53 PM(UTC)
Yes, This
Like mentioned : XAML
Xavi137
#8 Posted : Sunday, June 13, 2021 12:38:41 AM(UTC)
Xavi137
Yes, This
is not what is in the video.
I have to feed xls spreadsheet content.
here is an example of what I am looking for
Chyron
a test block right after the other text block, regardless of the length of both texts.
#9 Posted : Sunday, June 13, 2021 12:59:19 AM(UTC)
Chyron
Yeah, like you do know entering text manually or linked to a data source is the same not ?
Just because the example doesn't have the rectangular background ( which one can set to a color instead of transparent )does not mean this is NOT what you are looking for and fact is it can not be done with GT title
Xavi137 on 6/13/2021(UTC)
Xavi137
#10 Posted : Sunday, June 13, 2021 3:56:39 AM(UTC)
Xavi137
Chyron
thank you
I look forward to further GT updates
Xavi137
#11 Posted : Sunday, June 13, 2021 4:36:55 PM(UTC)
Xavi137
Add that the first question was only half resolved.
Yes, the size of the box can be variable depending on the text but only one text is selected at a time. If there are two lines in a box you have to choose one of the two.
But you can't choose both at the same time. It should be that the box should expand in size with the longest sentence regardless of whether it is one or the other.
Guest (10)
