GT
Does Gt designer have the function of a variable size box depending on the length of the text?
In other words, the width of the box adjusts perfectly and automatically according to the length of the text.
Joined: 12/27/2012(UTC) Posts: 5,520  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Yes
vMix YT has a video for it (Auto Scaling Titles)
I've already made it. Thank you very much. Two more questions: Two blocks of text that you want to go in the same line. One right after the other. Then the function to make the text size smaller if all the text does not fit in the rectangle. Thanks in advance
Originally Posted by: Xavi137  Two blocks of text that you want to go in the same line. One right after the other.
Assume you mean they position of second has to adjust its position according the length of the first ? Not with GT title but can be done with Legacy XAML titles Quote: Then the function to make the text size smaller if all the text does not fit in the rectangle.
If you hover over this button one gets the message : "Configure Automatic Text Box Resizing"  resize.JPG (22kb) downloaded 0 time(s).
The second question I have already found.
It is "Shrink" but it is not to my liking. It should combine auto scaling box up to a limit and then go to reduce font size. A combination of "Width" and "Shrink".
Yes, This The reason is to be able to make two different fonts in the same sentence.
Yes, This Like mentioned : XAML
Originally Posted by: doggy  Originally Posted by: Xavi137  Originally Posted by: doggy
Yes, This Like mentioned : XAML is not what is in the video. I have to feed xls spreadsheet content. here is an example of what I am looking for  a test block right after the other text block, regardless of the length of both texts.
Originally Posted by: Xavi137  is not what is in the video. I have to feed xls spreadsheet content. here is an example of what I am looking for  a test block right after the other text block, regardless of the length of both texts. Yeah, like you do know entering text manually or linked to a data source is the same not ? Just because the example doesn't have the rectangular background ( which one can set to a color instead of transparent )does not mean this is NOT what you are looking for and fact is it can not be done with GT title
Originally Posted by: doggy  Originally Posted by: Xavi137  is not what is in the video. I have to feed xls spreadsheet content. here is an example of what I am looking for  a test block right after the other text block, regardless of the length of both texts. Yeah, like you do know entering text manually or linked to a data source is the same not ? Just because the example doesn't have the rectangular background ( which one can set to a color instead of transparent )does not mean this is NOT what you are looking for and fact is it can not be done with GT title thank you I look forward to further GT updates
Add that the first question was only half resolved.
Yes, the size of the box can be variable depending on the text but only one text is selected at a time. If there are two lines in a box you have to choose one of the two.
But you can't choose both at the same time. It should be that the box should expand in size with the longest sentence regardless of whether it is one or the other.
GT
