Feature Requests
Different audio processing when using SeparateMono setting
Joined: 9/16/2020(UTC) Posts: 11  Location: Limburg Was thanked: 1 time(s) in 1 post(s)
I would love to see separate audio processing for each audio channel when an input is set to SeparateMono. For instance; I have two mics which are embedded in a SDI signal and I would like to independently route them to WTAutoMixer. The only workaround I've found so far is to use 2 busses and route the audio using the channel matrix.
Joined: 4/23/2017(UTC) Posts: 1,463  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Joined: 1/25/2019(UTC) Posts: 330  Thanks: 23 times Was thanked: 84 time(s) in 64 post(s)
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
+1 When I use Rode Wireless Go 2 Mics, they come with two transmitter/mics per set, along with one receiver. So when I connect the receiver to my Behringer UMC404HD, both mics come into vMix as a single ASIO input and there seems to be no way for the WT Automixer VST plugin to separately duck one mic's audio when it's not being used.
So I end up having to bring in a single Rode Wireless Go 2 mic from each of two separate sets and thus use a separate receiver plugged into the audio interface for each mic used.
Feature Requests
