bacu89
#1 Posted : Wednesday, June 9, 2021 1:30:28 AM(UTC)
bacu89
Netherlands
I would love to see separate audio processing for each audio channel when an input is set to SeparateMono.
For instance; I have two mics which are embedded in a SDI signal and I would like to independently route them to WTAutoMixer.
The only workaround I've found so far is to use 2 busses and route the audio using the channel matrix.
mavik
#2 Posted : Thursday, June 10, 2021 10:13:03 PM(UTC)
mavik
+1
Peter1000
#3 Posted : Friday, June 11, 2021 1:50:37 AM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
+1
mgrayeb
#4 Posted : Tuesday, September 21, 2021 2:14:19 PM(UTC)
mgrayeb
+1 When I use Rode Wireless Go 2 Mics, they come with two transmitter/mics per set, along with one receiver. So when I connect the receiver to my Behringer UMC404HD, both mics come into vMix as a single ASIO input and there seems to be no way for the WT Automixer VST plugin to separately duck one mic's audio when it's not being used.
So I end up having to bring in a single Rode Wireless Go 2 mic from each of two separate sets and thus use a separate receiver plugged into the audio interface for each mic used.
