 Joined: 6/9/2021(UTC) Posts: 1  Location: Cormano (MI)
                 Hello, this is quite wierd one,  after a graphic object (Button, Lable etc..) has been cloned or C&P,  it cannot be longer removed ("Del" button) from the Canvas. Also, the "info box" does not show any properties of the selected object as you might expect. maybe something wrong with my settings?
  Ver. 4.0.29 Cheers
                you should go to 3rd Party Software posts, and see how to do that.....everything related to Panel Builder is posted there.......and I have been using panel builder from day one, and do not have that issue.....
