marcocasagr
#1 Posted : Wednesday, June 9, 2021 6:51:27 PM(UTC)
marcocasagr
Italy
this is quite wierd one, after a graphic object (Button, Lable etc..) has been cloned or C&P, it cannot be longer removed ("Del" button) from the Canvas.
Also, the "info box" does not show any properties of the selected object as you might expect.
maybe something wrong with my settings?
Ver. 4.0.29
Cheers
Joeboe
#2 Posted : Wednesday, June 9, 2021 9:23:22 PM(UTC)
Joeboe
you should go to 3rd Party Software posts, and see how to do that.....everything related to Panel Builder is posted there.......and I have been using panel builder from day one, and do not have that issue.....
Similar Topics
vMix Panel Builder audio on/off button (3rd Party Software and Development)
by Utpc 7/23/2023 3:04:05 PM(UTC)
[vMix Panel Builder] vCall Name Change breaks button link (3rd Party Software and Development)
by rcdncn 10/19/2021 2:24:26 AM(UTC)
vMix Panel Builder - Layer para Calls (3rd Party Software and Development)
by HuperSom 2/10/2021 3:58:14 PM(UTC)
Programmable Controller for Windows/Mac- ( *replaced with vMIx Panel Builder) (3rd Party Software and Development)
by raugert 9/6/2017 7:35:34 PM(UTC)
