Joined: 2/21/2021(UTC) Posts: 6  Location: Fresno, CA
Please make the ONCOUNTDOWNCOMPLETION with a countdown to a specific time work to activate triggers when it reaches the time it is counting down to.
Originally Posted by: vineyard  Please make the ONCOUNTDOWNCOMPLETION with a countdown to a specific time work to activate triggers when it reaches the time it is counting down to. Until FR granted use a script https://forums.vmix.com/...ng-for-Dummies#post74242and adapt to your use
Unfortunately, I only have the HD version of vMix and scripting isn't allowed. While the script option may be a "fix" to the issue, it doesn't really solve what I feel is a bug on the trigger function. ONCOUNTDOWNCOMPLETION should be the completion of a countdown timer or the completion of a countdown to a specific time. I know a little bit about programming and maybe I'm just ignorant, but it doesn't seem like there would be a whole lot of coding necessary to make this happen with vMix itself.
This is not a bug but unavailable feature
also the triggers work on the countdown , NOT on the clock of which Countdown to time is part of
Even with HD versions one can use scripting aka coding be it with external apps on creates as how it was done before scripting was available.
Indeed with scripting it only would take a couple of lines of coding
FYI is what i do exactly for this reason still as not all licenses are higher end during a production (often even more functional and suited to one's needs)
FYI is what i do exactly for this reason still as not all licenses are higher end during a production (often even more functional and suited to one's needs) Can you tell me how I can run a script outside of vMix? I'm fairly new to all of these and I can see the power of scripts. If it's possible without the 4k I'd love for you tell me how to do it. Thanks
Originally Posted by: vineyard  Can you tell me how I can run a script outside of vMix? I'm fairly new to all of these and I can see the power of scripts. If it's possible without the 4k I'd love for you tell me how to do it.
Basically any program language (compiler) that allows you to do a httprequest (web API) to send functions to vMix and read the API XML to get a vMix status are suitable. if you still need to learn coding than maybe using Visual Studio and in vb.net language might be a good option as vMix scripts also use vb.net (in a more simplified functionality) Lots of stuff to be found with Google Search regarding vb.net programming
