Hello does anyone know why vmix freezes when i adjust the source frame delay (under advanced) (10-30 frames in average) using a BMD 8ch SDI capture device. The only way i can unfreeze it is when i re connect that source (in general Change to that source again)
It doesn't freeze all the time just here and there.
Thank you
we have a BMD Duo 2, here it's working again if we reset (right mouse click) the input happens after about 10 to 15 hours or restart vMix also solves the issue
 1 user thanked xaver for this useful post.
yes that is the one we use as well the BMD Duo 2 I wonder if that is the card or vmix...
