BigApple
#1 Posted : Thursday, June 3, 2021 1:16:05 AM(UTC)
BigApple
Hello does anyone know why vmix freezes when i adjust the source frame delay (under advanced) (10-30 frames in average)
using a BMD 8ch SDI capture device. The only way i can unfreeze it is when i re connect that source (in general Change to that source again)
It doesn't freeze all the time just here and there.
Thank you
xaver
#2 Posted : Thursday, June 3, 2021 2:35:25 AM(UTC)
xaver
we have a BMD Duo 2, here it's working again if we reset (right mouse click) the input
happens after about 10 to 15 hours
or restart vMix also solves the issue
thanks 1 user thanked xaver for this useful post.
BigApple on 6/3/2021(UTC)
BigApple
#3 Posted : Thursday, June 3, 2021 2:55:49 AM(UTC)
BigApple
yes that is the one we use as well the BMD Duo 2
I wonder if that is the card or vmix...
