GregDarling
#1 Posted : Thursday, May 27, 2021 4:48:25 PM(UTC)
GregDarling
Denmark
Hi. It could be very nice to have the possibility to have addetive solo button and maybe a function to choose that or not. Thx. Gregers
cookdoeyl
#2 Posted : Sunday, May 30, 2021 4:46:22 AM(UTC)
cookdoeyl
Was thanked: 8 time(s) in 6 post(s)
If you right-click on the Solo button, it adds that input to the other inputs currently solo'ed. Left Click replaces.
GregDarling
#3 Posted : Friday, June 4, 2021 5:29:03 AM(UTC)
GregDarling
Denmark
Hi. Thanks for the answer. It works but it only works on the inputs.
It should work on both the inputs and the outputs.
Chris Daum
#4 Posted : Friday, June 4, 2021 6:22:25 AM(UTC)
Chris Daum
Germany
You can "Solo" all audio busses exept "M", which are in the end your outputs
if you script it e.g.
api.function("SoloOn", input:= (your inputs))
aso
and
api.function("BusXSoloOn", value:= "A")
if you then create a shortcut function = "ScriptStart" value = "your script"
you can add as many IN/OUTs to your "solo card" as you wish.
or you create only one script and combine all solos in one preset
api.func...("Solo..., input...)
api.func...("BusX..., value...)
GregDarling
#5 Posted : Friday, June 4, 2021 6:45:41 PM(UTC)
GregDarling
Denmark
aso
and
Please read my original post. I'm normally a soundguy so the script thing should be last Move :-)
Guest (4)
Similar Topics
Make audio Solo button yellow and blinking when activated (Feature Requests)
by mbienvenue 12/3/2020 6:31:50 AM(UTC)
New Feature: Solo Button-Overlay-Merge project-VmixCall (Feature Requests)
by AlexITA 10/30/2018 3:43:50 AM(UTC)
vMix Solo button operation? (General Discussion)
by Videoguy16x9 9/20/2017 1:53:45 PM(UTC)
solo button in audiomixer (Feature Requests)
by Ittaidv 3/24/2014 1:17:01 PM(UTC)
