Hi. It could be very nice to have the possibility to have addetive solo button and maybe a function to choose that or not. Thx. Gregers
Joined: 12/12/2018(UTC) Posts: 23  Thanks: 1 times Was thanked: 8 time(s) in 6 post(s)
If you right-click on the Solo button, it adds that input to the other inputs currently solo'ed. Left Click replaces.
Hi. Thanks for the answer. It works but it only works on the inputs.
It should work on both the inputs and the outputs.
Joined: 11/20/2020(UTC) Posts: 74   Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
You can "Solo" all audio busses exept "M", which are in the end your outputs
if you script it e.g. api.function("SoloOn", input:= (your inputs)) aso
and api.function("BusXSoloOn", value:= "A")
if you then create a shortcut function = "ScriptStart" value = "your script" you can add as many IN/OUTs to your "solo card" as you wish.
or you create only one script and combine all solos in one preset api.func...("Solo..., input...) api.func...("BusX..., value...)
Originally Posted by: Chris Daum  You can "Solo" all audio busses exept "M", which are in the end your outputs
Please read my original post. I'm normally a soundguy so the script thing should be last Move :-)
