Ms Teams with virtual audio input
I'm using VMix for hybrid versions of zoom & teams meetings. where I activate virtual audio cable to add audio input to teams or zoom at the same time master output for the physical audience. Recently I'm facing a trouble when I use ms Teams, that when I activate M (master) it cut the sounds for ms teams (bus A). again when I deselect M, can hear audio from ms teams. With zoom it works fine with both ways. anyone else faced the same thing? appreciate if anyone who solved this can help me. TIA
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Is Teams run on a separate machine?
Did you ever solve this? I don't use the Master to send to the room, but rather create a second bus (Bus B) for the room. This lets me select which inputs I want in the room.
My problem is that I'm sending my room audio out through a USB audio interface and it sends every audio source to the room instead of ONLY the ones I select for Bus B.
