Nalina
#1 Posted : Wednesday, May 26, 2021 5:27:44 PM(UTC)
Nalina
Sri Lanka
I'm using VMix for hybrid versions of zoom & teams meetings. where I activate virtual audio cable to add audio input to teams or zoom at the same time master output for the physical audience. Recently I'm facing a trouble when I use ms Teams, that when I activate M (master) it cut the sounds for ms teams (bus A). again when I deselect M, can hear audio from ms teams.
With zoom it works fine with both ways. anyone else faced the same thing? appreciate if anyone who solved this can help me. TIA
Vince Beck
#2 Posted : Thursday, May 27, 2021 11:43:28 AM(UTC)
Vince Beck
Is Teams run on a separate machine?
Nalina
#3 Posted : Thursday, May 27, 2021 5:52:18 PM(UTC)
Nalina
Sri Lanka
no in the same machine
ward@wardcameron.com
#4 Posted : Wednesday, April 6, 2022 7:26:15 AM(UTC)
Canada
Did you ever solve this? I don't use the Master to send to the room, but rather create a second bus (Bus B) for the room. This lets me select which inputs I want in the room.
My problem is that I'm sending my room audio out through a USB audio interface and it sends every audio source to the room instead of ONLY the ones I select for Bus B.
